From Pan to carb here goes-
69' 318 Block .030 and decked 0.010
SCAT 9000 Crank 4.00 2.500 2.125
SCAT 4340 I-Beam Rods ARP 2000 bolts
ICON Forged -23cc dish 594grams
Clevite MS540HX +.001
Clevite H series Rod STD
ARP main studs 12pt (Had to order the low clearance bolts for #5 main to clear oil pump)
Meiling HV oil pump
Felpro 1008's
Total Seal File fit rings 1/16Moly 1/16 3/16
Comp 282S Magnum cam 282/282 adv 236/236 @ .050 .495lift w/ 1.5
Comp 995 Springs installed at 123lb seat 321lb open
Comp retainers and locks
69' 340 X Heads Ported, 3 angle, 2.02 1.60 Manley, cut .035" to 60cc chambers (Rough flow as I did not have them checked but 270cfm)
Proform Roller Rockers 1.5 (These have been good to me but I will go to either PRW steel or Comp Magnums in the future)
Summit Air-gap matched to heads
AED 750CFM No Choke Mech Secondaries
Shorty 1 1/2 Headers to 2.5 Full dual exhaust
Specs-
9.75:1 Compression
Goal-
To get my 3000lb Dakota into the 12's
