Beware when ordering these kits with the electric cutout and cutout tubing that they are only made to fit ONE SIDE! There is not an opposite to mirror the fitment to the other side. I stayed up until 3 am last night (still made it to work at 7) getting the entire exhaust built, only to find out that the driver's side cutout will only work if you install the motor UNDER the exhaust pipe pointing the same direction as the passenger side. This is obviously a hazard of ripping the motor completely off. Since I only happened to check the passenger side for the angle of the cutouts because that's where I was most concerned with clearance, I'm kinda screwed now. I was assuming that they gave an opposite part in the kit since nothing was adjustable. But not the case. Else I would have cut the flange off and rotated it while out of the car and re-welded it back. But now it's all in place, bolted in and painted. :banghead: I thought maybe I got 2 right side cutouts in my kit, but according Summit (I stumped their tech guys for 40 minutes on the issue until they finally understood), the cutout pipes and electric cutouts are all identical and they told me it's not their problem. They said I'll have to cut the flange off and re-weld it or install one with a rotating flange. Yeah real easy to say sitting at your desk A$$HOLE! Why didn't you provide that in you're piece of **** kit!? Summit can go get bent as far as I'm concerned. I'm done with them. And I'll put money on it that one of these cutouts will leak and I'll still have to return them. Sorry for the rant but I'm tired and extremely irritated at the moment. I just wanted to give a heads up cause I know these are tempting to buy due to their price point. I got suckered into it obviously.
