My Demon 5.7 hemi carb swap
It's a 6.4
attachment.php
What's the engine combo and do you have any et's yet?
6.4L 10:5 comp. so I can run pump gas, 608 lift cam, extensively ported heads, 2 600 cfm carbs. around 600hp and still very streetable. 4500 stall 727 and 488 gears on a 9 inch. 6.50s in the 8th on mickey Thompson street tires so it has to be babied off the line.
What size of rear wheel/offset are you using, and what size of tire? I assume you have full tub.
