I just went there to the tools and the pull down link for starting a thread says for sale, trade, sold all same options as for sale section so should work now.
The "cam deals" are for stretching wire or acting as a short 'wench.' YOU DO LIKE "short wenches" doncha?Just not too sure I'd recommend his method...............
The cams are for gripping fence wire when stretching fence (like barbed wire). They have a small base plate and are quite unstable when using them as a bumper jack. toolmanmike
Thanks, I have a nice 3/8" plate of steel laying around. I will double the size of the base and bolt it on so it can be removed if not needed.
Every time I use mine I keep a can of Liquid Wrench nearby...Lubrication on the lift mechanism is key to reliability of a highlift.
I've been using the same highlift for many years.
it is more than just a jack, has many other uses.
Neither does mine....I think.....Now that I am curious when I go out to lock the garage I will be looking....I have 2 of them and neither has the "cams".
What? We don't have a tool section?
Of course we have a tool section http://www.forabodiesonly.com/mopar/forumdisplay.php?f=104
That is weird, the extras section is minimized when I look at the forum list so I overlooked it.
hmmm, Over on the right hand side of the page in the red header there are 3 dots in a triangular pattern "For A Bodies Only Extras". Try clicking that to see if the Extras Forums show up ??
