MOPARJ
What can I upgrade now?
Currently running a 318, with 46K since the rebuild about 5 years ago. Comp XE268 cam, headers, double roller timing chain, electric choke Street Demon 625 carb, FBO distributor. Always use Delo 15w40 oil and good Wix filters every 1500 miles, and it used zero oil. 17-20 psi oil pressure at hot idle (at lowest), 55-60 psi at speed always. Motor runs good. Maybe 10 quarter mile passes and a romp to 5K rpm out on the road here or there. Switched over to 3.91 gears about 3 months ago. I limit the freeway revs to 3200-3500 rpm tops, maximum 70 mph. If I keep up on the maintanence, do you feel the motor has plenty of life left before overhaul?
Eventually will be getting OD A833 down the line.
