[WANTED] federal PS pump parts
chopsuey68
Member
Benicia
I am looking for parts for a federal PS pump, for a small block. I need a pulley (press on, no keyway), brackets, and a reservoir cap. Any help is appreciated. I will buy with a pump too. I can pay with paypal and am located in California.
Thanks
chopsuey68,
I bought a pulley from
http://www.marchperf.com/chrysler-vbelt-pulleys.html
If I remember correctly it was #532 for the Federal pump for my car (1971 Dart GT).
Unfortunately, I have a misalignment issue between the PS Pump and the CRANK pulley. Looks like the PS Pump needs to move back (toward the engine) ~3/16". It also appears the MarchPerf pulley is fully seated on the PS Pump's shaft. It has been running this way for several years (about 3,000 miles), but I'm looking into modifying the brackets to allow for some rearward adjustment.
I may also have the pump cap if you're interested.
Is this the setup that you are looking for?
I have attached a photo of the Federal pump that I need, as well as the brackets.
