junior636
Looks good, wish i was as close as you are! I always think, ahhh i can do that in a day, ends up taking 3 or 4.
Given any though to sinking the fuel cell into the truck floor (lower center of gravity weight wise)?
Only ask because thats the stage Im at. I had a smaller 12 gallon sitting in trunk but decided I wanted to drive more than 10 minutes from every gas station and went to a 22 gallon. Now, after already fabbing a sheet metal floor and running hard lines, Im going to have to revamp it all to get the new cell to sit lower.
Don't you work? Lol
What kind of Rear suspension do you have?
A mishmash of super stock springs and 3 way adjustable shocks with a set pinion angle (no snubber) on a narrowed rear end. The whole unit came from a drag car (duster) and was too good a deal to pass up although now that Ive shifted the build from drag to street/touring, the mini spool might make things a little interesting![]()
Other than the sub frames, Im still piecing the suspension components together. Need to figure out a sway bar, boxing the front, what front shocks...
That looks awesome! If you don't mind me asking, what are running for trans cooler lines?
Also, what size is that fuel line are you using?
what did you paint your exhaust with? is that all ceramic coated? have you fired it up with the new pipes? hows the twerk chamber sound?
haha no wheels the new mopar hovercraft![]()
Awesome job. Looks great.
