10 sec Cuda
Hot Metal
'69 440 Cuda
UK
Back in 1990 I ran a 10sec '69 Cuda-3000lbs at the line...here's the spec
440 6-pack bottom end, 10.3:1CR
906's ported 2.14/1.81
Team G intake, worked 850DP
2" fenderwells
CCams .650 solid [email protected]
HS Roller Rockers
Manual 727, 8" 4200stall
MSD6A
Ladder Bars/coil overs
Richmond 4.88 gears
Hoosier 14x32 tyre
Milodon single external oiling
10.71@125
1.46 60ft
hit it with a 175 shot and went 9.96@134
but only did that once as trap was 7400rpm!!!!
sorry should've gone in the 10 sec combo section.
Here's a few more......
Here's a vid of the 9.96 run at the Anglia TV meet at SP in 1990.
watch from 1.13>1.32
Vintage Coooool ****. One could still run this identical combo today and do quite well.
Yeah would've liked 12.5:1 for that cam and more Head as they were only around 265cfm, (didn't have Ally heads then apart from B1=$$$$$), but it seemed to work well, big duration kept the valves open....ticked over at 900 and pulled like a train top end....those heads got me .5 sec over stock 906's though.
here's some more vintage footage from the Pod......doing some 10.90 index racing, stock headed motor.
[ame="https://www.youtube.com/watch?v=RnFPqPQTThM"]Santa Pod Mayday Springnat's 1990 part 2 - YouTube[/ame]
from 2.34>
[ame="https://www.youtube.com/watch?v=S8fm5ffChiw"]Santa Pod Mayday Springnat's 1990 part 5 - YouTube[/ame]
from 13.53
Nice, im working on a similar build hoping for the same results, but your chassis is deffinately better than mine will be, but awesome car!
Yeah, I bought my '69 all complete running with 440/727 for $4500 at todays rate, was a street car on springs. Had a fellow Racer back half the car at his garage, supply and fit l/bars, did all the Tin work, made the f/wells, I had the motor balanced, bought the inlet/cam/converter, 2.14 heads and had the box raced up, 4.88's, Strange spool 35sp shafts, 14x32's, coil overs, External oiling system etc. etc., in fact race ready for around $15000:D....that was in 1989.
