Check out all the things it doesn't come with:
BluePrint Engines Chrysler 408 Stroker 375HP Value Power Base Crate Engines BPC4082CT
BluePrint Engines BPC4082CT - BluePrint Engines Chrysler 408 Stroker 375HP Value Power Base Crate Engines
Image is a representation of this item.
Actual item may vary.
In progress Get Totally Free Shipping with Your Order!
$3,595.00
+Compare
Free Shipping Over $99
Low Price Guarantee
Tech Advice
Easy Returns
Summit Racing
Be the first to Review this product
Engine Assembly, Long Block, Base, Magnum Iron Heads, Oil Pan, Mopar, Small Block LA, Each
Estimated Ship Date: Tomorrow
Would you rather pick it up? Select Location
Check Application
Order this item and get free delivery and handling on your entire order! Truck freight fees also waived on this item. Valid on orders shipped in the contiguous United States.
View Similar Products
See parts for BluePrint Engines
Part Type:
Crate Engines
Application:
Find out if this fits your application
Brand:
BluePrint Engines
Manufacturer's Part Number:
BPC4082CT
Part Type:
Crate Engines
Product Line:
Summit Racing Part Number:
MLL-BPC4082CT
Engine Assembly Style:
Long block
Crate Engine Cylinder Head Material:
Cast iron
Assembled:
Yes
Engine Balance:
External
Intake Manifold Included:
No
Cylinder Heads Included:
Yes
Carburetor Included:
No
Throttle Body Included:
No
Distributor Included:
No
Oil Pan Included:
Yes
Valve Covers Included:
Yes
Timing Cover Included:
Yes
Water Pump Included:
No
Harmonic Balancer Included:
No
Flexplate Included:
No
Flywheel Included:
No
Air Cleaner Included:
No
Spark Plugs Included:
No
Spark Plug Wires Included:
No
Computer Included:
No
Wiring Harness Included:
No
Rear Main Seal Style:
2-piece
Quantity:
Sold individually.
Notes:
Magnum heads.
In-Store Pickup:
Choose In-store pick-up (OH, GA, NV) on our web site.
Calculator
CFM Calculator
Budget minded hotrodders rejoice! These BluePrint Engines Chrysler 408 Stroker 375HP Value Power base crate engines are for you. BluePrint developed these engines for those wanting reliable stroker power without breaking the bank. Each mill is hand assembled and balanced to ensure it will run smooth and strong, just what you need in your muscle car.
These BluePrint Engines Chrysler 408 Stroker 375HP Value Power base crate engines include:
* Handpicked, seasoned and machined blocks
* Performance Magnum cast iron cylinder heads
* Cast iron crankshaft and heavy beam connecting rods
* Hypereutectic pistons
* Hydraulic flat tappet camshaft
* Valve covers
* Timing cover and timing set
* Oil pan, pump and pickup tube
Warranty
Some parts are not legal for sale or use in California on any pollution-controlled motor vehicles
Click here for more information about Summit Racing SUM-G100SFI - Summit Racing Street & Strip® SFI-Approved Flexplates
Flexplate, 168-Tooth, Internal Engine Balance, 2-Piece Rear Main Seal, SFI 29.1, Chevy, V8, Each
$52.97
Click here for more Detail about Summit Racing SUM-G100SFI - Summit Racing Street & Strip® SFI-Approved Flexplates
Click here for more information about Holley 0-3310S - Holley 4160 Adjustable Float Carburetors
Carburetor, Model 4160, 750 cfm, Square Bore, Manual Choke, 4-Barrel, Vacuum, Dual Inlet, Silver, Each
$323.95
Click here for more Detail about Holley 0-3310S - Holley 4160 Adjustable Float Carburetors
All Suggested Parts Carburetors
Flexplates
Spark Plugs
+ SEE ALL SUGGESTED PARTS
