[SOLD] 67-72 factory 340/360 engine mounts
273 and 318 use a different driver side mount than 340 and 360... They all use the same pass.side.
i have all the fine thread bolts an nuts for these too.
i think the left side is 3/8 narrower than the right side
this should show the difference....top pic is a 340 mount on a 340...
bottom pic is a 273/318 mount.
Miike is correct.You should weld on the third ear if using a 318 drivers' side mount on a 340 or 360 and a 1/4" spacer as well.
