mikebee now's the new later... Joined Feb 23, 2011 Messages 1,975 Reaction score 153 Location n.c. Rating - 100% 27 0 0 Mar 24, 2015 #1 Contact seller 100$ & shp from NC 28001 postal money order only! thanks! Attachments image.jpg 64.8 KB · Views: 308
tekslk Well-Known Member Joined Dec 13, 2009 Messages 3,140 Reaction score 95 Location McClure, Pa Rating - 100% 2 0 0 Mar 24, 2015 #2 Are they 340 or 360 I thought they were two different animals?
greymouser7 Vagrant Vagabond “Veni Vidi Vici” Joined Apr 17, 2010 Messages 3,729 Reaction score 1,457 Location 78002 down the road from Atascosa, Texas Rating - 100% 20 0 0 Mar 24, 2015 #3 Yeah I need to know that to, I'm beginning to mix it up. Is it 273/318/340 engine mounts & 360 is different right?
R rick hughes 71dusterdude Joined Jan 21, 2009 Messages 209 Reaction score 5 Location wv Rating - 66.7% 2 1 0 Mar 24, 2015 #4 340 & 360 are the same
mikebee now's the new later... Joined Feb 23, 2011 Messages 1,975 Reaction score 153 Location n.c. Rating - 100% 27 0 0 Mar 24, 2015 #5 what he said....360 and 340 are the same
Dustem Active Member Joined Feb 4, 2009 Messages 29 Reaction score 0 Rating - 0% 0 0 0 Mar 25, 2015 #6 318 uses different drivers side mount.
mikebee now's the new later... Joined Feb 23, 2011 Messages 1,975 Reaction score 153 Location n.c. Rating - 100% 27 0 0 Mar 25, 2015 #7 273 and 318 use a different driver side mount than 340 and 360... They all use the same pass.side.
mikebee now's the new later... Joined Feb 23, 2011 Messages 1,975 Reaction score 153 Location n.c. Rating - 100% 27 0 0 Apr 1, 2015 #8 i have all the fine thread bolts an nuts for these too.
keggy1969 Well-Known Member Joined Oct 27, 2011 Messages 212 Reaction score 24 Location hagersville Rating - 80% 4 1 0 Apr 13, 2015 #9 i think the left side is 3/8 narrower than the right side
mikebee now's the new later... Joined Feb 23, 2011 Messages 1,975 Reaction score 153 Location n.c. Rating - 100% 27 0 0 Apr 14, 2015 #10 keggy1969 said: i think the left side is 3/8 narrower than the right side Click to expand... this should show the difference....top pic is a 340 mount on a 340... bottom pic is a 273/318 mount. Attachments IMG_1936.jpg 63.7 KB · Views: 121 IMG_1923.jpg 52.3 KB · Views: 133
ir3333 Well-Known Member Joined Jun 1, 2008 Messages 5,845 Reaction score 1,595 Location ontario,canada Rating - 100% 2 0 0 Apr 14, 2015 #11 Miike is correct.You should weld on the third ear if using a 318 drivers' side mount on a 340 or 360 and a 1/4" spacer as well.
mikebee now's the new later... Joined Feb 23, 2011 Messages 1,975 Reaction score 153 Location n.c. Rating - 100% 27 0 0 Apr 15, 2015 #12 fo sold!
