OE correct dimpled electronic voltage regulator 1970-early72
sawdust
Member
Green Lane, PA
Rating - 0%
0   0   0
Correct dimple OE Electronic Voltage Regulator
Excellent original 1970 through 1971 electronic voltage regulators for all A, B, C and E-body mopars,
These are original regulators NOS from OE supplier bin lots as was the case for the production. The regulators have been cosmetically restored to OE correct level, fully tested on an operational charging system with an alternator, battery, and 30 amp loads. Regulators are tested for voltage output, voltage stability output, voltage output under load, and voltage after lamp load. (Others on the market are not tested or if you are lucky, only bench tested, not system tested for load and output). I have both the early style tapered flange case used before January 1970 and the later style case with a stepped flange. Each regulator comes with the correct mounting screws, and a one year warranty.
Dates available:
319, 349, 379, 439, 469, 509, 040, 070, 110, 160, 210, 260, 350, 420, 021, 091, 151, 201
$99 with free shipping to lower 48
Green Lane PA
in your example are they 21st week 1970 and 43 week 1969?
would both be correct for 1970 models?
I still sell the voltage regulators but have not updated pricing on the regulators.
For the past two years the price has been $120 shipped, continental US. Do not get on a-bodies only much being I have 1 post in three years. Nromally stick to Moparts.
Thanks.
Yes both are correct but I supply more date codes that can get you closer to your SPD. Also, the two different case styles for before 01/1970 and the later for after. Hope this helps.
