turbshelbys
Member
I do apologize if this has been covered, but looking to replace my worn out springs. Part #'s or different makes and models that will fit? Thank you so much
I wouldn't get any of those linked items, no. I'd go directly to ESPO, call them on the phone and order their 5-leaf springs. They have a long history of getting this right. Results and reviews have been thoroughly mixed for those Hotchkiss items, especially.
Was thinking of getting these?
http://www.ebay.com/itm/Hotchkis-24...prings-Geometry-Corrected-1-Drop/331399026276
or
http://www.summitracing.com/parts/dcc-4120864/overview/year/1966/make/plymouth/model/barracuda
http://www.summitracing.com/parts/dcc-4120863/overview/year/1966/make/plymouth/model/barracuda
those types could't be further apart in application.
the hotchkins are more for handling. very good spring for that purpose.
the mopar performance ones are for drag racing. car will sit high and 90% of the time lopsided.
espo are a nice stock replacement. personally i don't like their 5 leaf springs. have had far better luck with their 6 leaf springs. eithe rway their customer service is awesome..
i'm running eaton springs on our dart now.. haven't put too many miles on them yet though.
I do like the way it sits but the ride is terrible. The pass side leaf has started to separate as well.
i have found that when you put the slightest things in the trunk the 5 leaf sag pretty bad. they go back to sitting normal with nothing in the trunk but boy do they drop fast with anything in the trunk..
If you want it to sit jacked up like that you're going to be hard pressed to get a decent ride out of it.
The torsion bars must be jacked up to the moon and if you go with new thicker bars they are going to be stiffer than what you have. Air shocks are not going to improve your ride. I'm unsure if you are getting that height out of the air shocks or the springs. I'll assume the shocks, which is affecting the ride quality. But to get the 4x4 look out of a spring it will most likely have to be a +x over arch. Again, this isn't going to help your ride quality.
