I see you had a former AC car with that valve on the passenger side of the inner fender. I was worried about the ugliness of putting that valve back in my car (sans AC), but your set up gives me hope that it can still be done cleanly.
Are you, or did you put the marking's back on the rear axel? You had good photos of them prior to re-paint!
I have the original AC Hardware but have decided to put a Sanden unit in there eventually.
Initially i thought the same as you, and thought is was going to look bad but I am happy with the way the heater hoses routed.
red69 said:Hi AIV I was wondering if you had or could take a picture of the pass side parking brake cable routing if it goes along the rear axle and where it is clamped? I bothered you once before on the Detroit muscle tech stuff which by the way I too was happy with Thanks. Really enjoy your thread. Thanks Rick
Looks Really Great !! Great Progress !!
I also took the AC condenser completely out of the heater box and sealed up the vent opening with a piece of sheet metal inside the car and made a metal plate to cover the holes in the firewall. Would have taken the valve off the car, but I wasn't sure that the rest of the heater box controls would work properly and I didn't want to give up heat in my car all together.
Thanks Mitch!
I'm very close to the end but I'm starting to stall a bit. Fixing up loose ends with the wiring. And I have to pull out the steering column to install the dash but tah should happen this weekend.
I still have to give it a systems check to make sure every thing works and finally fire.
But before I fire I think I need to install a jumper across the ballast resistor. The reason I say that is because I think that is one way to tie "ign 1" to "ign 2" for the MSD controller although I could be wrong.
Looks like I'm working opposite of you. Got my GTS 383 fired up last week and broke in. Then I pulled the windshield since it was smashed from years ago. Thought I would just clean up the channel and replace all clips. But.... I dont like the paint on the dash frame. SO... Gonna pull the column and dash. See... Opposite You LOL.
Far as the jumper... I used Pertronix in my stock dist and , yes they did want me to bypass the ballast. What I did was Solder a 12ga wire behind it to keep it looking stock. It.s all in my build thread right below this.
Dash looks nice in the car Al, keep hammering at it!
Lookin good Al ! Pullin my dash today. Finished Steering Column.
Thanks Mitch!
Spent some time tonight setting up the carb linkage.
Installed the 20-7 Holley throttle stud adapter to relocate the stud for the throttle linkage.
The kickdown is adjusted following the master tech video
Does it look right?
Al,
What gasket did you use under that Holley? I was considering putting a 1/2" phenolic spacer under my carb, but I haven't committed fully yet. Thanks.
Carl
