[WANTED] WTB: Small block Manifold 4bbl and carb
Let me know if you're still looking because I have an SB Four Barrel Torker manifold with QFT 600 CFM carb combo for sale. Gaskets to install are included for $400 total. Have pics as well if you want them.
If you're still looking, I have an Edlebrock aluminum intake and 66 440 reman AFB.
Too bad you can't find a nice Edelbrock LD4B. they were designed for the small port 318 heads. You will also need to modify the throttle cable mount, the transmission kickdown, and other linkages if you change from 2 to 4 barrell. There are many helpful threads here on the subject.
Too bad you can't find a nice Edelbrock LD4B. they were designed for the small port 318 heads. You will also need to modify the throttle cable mount, the transmission kickdown, and other linkages if you change from 3 to 4 barrell. There are many helpful threads here on the subject.
What's this elusive 3 barrell you speak of? Haha : )
