ShortShot
Active Member
Finally got the engine into the Dart and ran across an issue with the PS pump pulley alignment. Seems to be off by about a quarter inch, did some research and it seems I have all the right parts in all the right places. On a 360 LA block, non A/C, and an aluminum water pump....does this look right or can someone spot something I did wrong? Pump came off the original slant 6 that was in the car so I suspect it may be slightly different or possibly the rear bracket that came off a 318 parts car is bent? Thanks in advance.
