Electronic Power Steering for My G3 Hemi Swap
'Cuda_ragtop
Woulda, Shoulda, 'Cuda!
Great Pacific Northwest
No Pumps, No Pullys, No Belts, No Hoses, No Fuid, No Leaks, No Engine Brackets, Less Parasitic HP Drain on the Engine. ~ 35% Less Steering Effort
Not the least expensive path to Power Steering but I do like all the benefits.
Electric Assist Power Steering with my Manual Box.
360 Watt
Will need to size alternator accordingly... Not a problem with modern alternator options.
Already planned for new steering column...
Unisteer Performanc EPS
Improved Electra-Steer Ididit Steering Column Kit
A 5 year old article
Electronic Power Steering - Street Rodder Magazine
Installation Manual:
file:///C:/Users/Randy/Desktop/657240%202in%20Column%20220-360%20Electra-Steer%20Kit.pdf
 The Unit is intended for normal highway use in vehicles not exceeding 4500 lbs (2000 kg).
 The column MUST be firmly anchored. All Torque required to steer the vehicle will be transferred through the column mounts.
 The unit CANNOT be mounted near a heat source, exposed to excessive moisture/water, or submerged under water.
 All Steering Shafts, Joints, U-Joints, and Connectors must be designed to withstand the full load of the steering system to which the electric motor is being installed.
 The Wiring, Module, and Motor must not be tampered with. Any modification to the Module or Motor will void any existing or implied warranties, if so offered.
Can't wait to see a mock up. AA- plus awarded, just for the effort.
I did a half way attempt with a unit off a midget (race car).....and gave in.....only so much room where that baby is required to reside.
Good luck.
I`d like to see finished interior pics of it on a 68 barracuda, there aint much room under there !
I would like to see finished pictures of it in my 69 Barracuda... :-)
Looks like there is a less expensive option by using Saturn Vue/Chev Equinox EPAS
Found quite a few examples on Youtube and other forums.
Anyone want a $100 electric power steering? Here you go! - Vintage Mustang Forums
So far, I have not found any EPAS conversions done on Mopars...
----o00o--'(_)'--o00o----
