Ok...So Mine has (Will Have) the same exhaust Manifold as Pictured above....Will the oil filter clear the Exhaust Manifold without issues??
Don't know IF I must get an an adapter,use a shorty,Or id a standard filter will still work.
From this angle,It loos like it will be fime as is,But not sure about Heat Issues?
Any thoughts would be appreciated.
Thanks,Eric
You have to use a 90° oil filter adapter with the 68-70 340 exhaust manifolds... Tilted down slightly at about 5° - 10°...
Then the oil filter will clear...
If you don't use the 90° adapter, the oil filter will definately hit the exhaust manifold... ---> tried it....
