I don't have a TQ on anything right now. Holleys. Just mak'n a point that the TQ's a working carb. I've tuned them and they've run great. You have stated you cannot tune them.
I'd have no problem taking you on any day, dollar for dollar, weight to weight, gear to gear. You have no ingenuity in your motor. Not a soul on this site couldn't achieve your ordering of eddy heads, and your pharmacy build (means you get a prescription from a "doctor", and drop off your engine at the machine shop, and pick it back up). A typical "run of the mill" catalog build. The only way you ever go faster is if somebody "does it better FOR you" the next time, which usually means you opened your wallet wider.
And, what's usually the case, these are the guys that after they open their wallets WIDE, they open their mouths WIDER
