i only used it once lolThey removed it to piss you off....![]()
still stuck herewell - you can really tell that it's gotten nicer out...
yea - but it really has gotten some kinda quiet over the last few daysstill stuck here
think I would wear welding gloves. lolFired that scope tool up it actually works! Scary to use but works!
just us crazy working fools I guess. All the retirees out partying in this nice weatheryea - but it really has gotten some kinda quiet over the last few days
What gauge? I'm guessing you need nice flexible stuff like SO cord.Need to find some five conductor wire that has black rubber over it for one run the rest are just two, Kinda hard to find without buying 50' of it need around 3 feet.
wooohoo - good luck!!! hang on to those E-brakes!!!!Good news.. I fired up the Post Car with the 440...The brake pedal was tight , so I figure it has brakes.. Put it in gear and moved it down off of the Gravel incline. no problem.. Now I gotta move the 4 dr with no steering column and no trans down. Then the 2 dr HT with no drive train. Wish me luck... That I don't roll em into the woods ....![]()
Yeah...Sure.. Problem is.. These other two have NO brakes... And I'm alone doing this... Will place tires in front every three feet or so as I push them down...![]()
I am beyond surprised that you don't have a come-alongYeah...Sure.. Problem is.. These other two have NO brakes... And I'm alone doing this... Will place tires in front every three feet or so as I push them down...![]()
So, your help all get turned around at the border?Yeah...Sure.. Problem is.. These other two have NO brakes... And I'm alone doing this... Will place tires in front every three feet or so as I push them down...![]()
I like my wenches electric.or even better - an electric wench
fixed itI like my wenches battery powered.
Yeah.. I gots one.. Just too lazy to go gits it I guess.. My Son and his Co- worker are gonna come by.. I couldn't budge it by myself. New 2 in stone under them....I gots a Plan....I am beyond surprised that you don't have a come-along
AC...DC.. Whatever it takes!fixed it
Lead from batt+ to + side of coil. power to starter. cross the solenoid post and voila!!Hey mitch. or well anyone, lets say I wanted to completely bypass the electrical harness on a 64 polara to temporarily try to see if it'll fire, or attempt to fire. Basically, can it be hardwired and bypass the melted, shorted out harness. All i'd need is power to the starter, coil/distributor right?
