Why not just slip the E-4 cam in the 273 and be done? Then take your time on a 318 or whatever.
you said you were trying to add about 50 hp and more low end torque???
Here is my 40 year old 318 (1976), short block never taken apart. Home ported the worst smog 318 heads on earth, and didn't even have them cut. Threw in the cheapest summit cam kit (109 bucks cam & lifters), and put on a spreadbore cast intake with a squarebore 670 holley. No headers, 2.76 gears, stock converter.... Low end no problem with me... I found the best traction road (chip seal) we have for street tires... still no dice, still spinning up to 50 mph and backing off just a tad to get it to quit
Also, I'm using the Fel pro head gaskets that are .050 thick! I have worse compression than a factory 318 that's never been apart. If I cut the heads .040, it would be a healthier. and no, if I cut the heads .040, I will not be cutting anything else. It will be just fine. Of the times I've done it, never an issue.... ever.Nicely done! Sounds good and pulls good too.
No. I've never cut anything but the head-to-block surface. Ever. I've never had an issue. Even if you use a .039 thick head gasket, your giving up about .014 to the original head gasket. So your .040 becomes only .026 of a gain, follow??? Like I said, I didn't cut the heads on the 318 I now have in my car because I was keeping the cost under 500 bucks. And i did keep the cost to 497.00Did you cut intake side as well? My machinist says yes but he doesn't have to mill the intake.
Thanks!
If you mill the heads .030 you should probably take some off the intake surface too. That way the heads can be swapped to another engine and any intake can be used.Did you cut intake side as well? My machinist says yes but he doesn't have to mill the intake.
Thanks!
As long as the zits are protrusions I would grab a Dremel tool and a small grindstone and remove them. Why mill the heads.
If they are pits have the machine shop look at them before they do any machining. They could cause hot spots and preignition/detonation.Not protrusions Mike. They are "pits/craters" small ones.
Im going to cc heads before milling. Then play with numbers to chk/compare ompression numbers
how far in the hole were the stock 85 318 pistons with stock deck height??I could go that route, but Im still thinking that with the factory 2bbl pistons I will be over camming it.
I was wanting to budget build a sb and still enjoy the cuda(if rain ever stops here LOL)
So I borrowed a dial indicator to help figure out compression ratios on 85 318 stock bore and appears stock pistons. Engine #2 is a 70 318 with .030" over TRW L2373. Heads are 302, not sure on comb chamber volume but I put 60 in. I will CC the heads and looking at milling them what I can without having to change from my stock adjustable valve train. I put 60 CC in there until I get more accurate numbers.
I used verniers to get how far in the hole.
Compression Ratio formula I got from net
Swept Vol +Deck Height Vol + Head Gasket Vol +Combustion Chamber Vol
Divided by Deck Height Vol + Head Gasket Vol + Combustion Chamber Vol
85 318 70 318
Bore 3.91 3.94
Stroke 3.31 3.31
Compression Height 1.72 1.67(DAMMIT!!)
Head gasket thk/vol (1121G) 0.028"/6.1763CC same
Comb chamber volume 60CC 60CC
DeckHeight Volume (averaged) 17.289CC 33.06598CC(OUCH! twice as much)
Swept Volume 651.779CC 661.3164(not looking good lol)
Constant Volume 83.465 99.242
All these numbers give me a comp ratio of 8.8:1 on the 83 318 and a horrible compression ratio of
6.7:1 on the 70 318.
My measuring techniques may be hokey at best, but it gives me an idea as to where I am at and it helps me wrap my head around the “science” of it.
As I mentioned the 302 heads will get cc’d and Im going to ask machine shop the safest amount to mill without having to change from stock adjustable valve train.
Besides being horrible numbers on 70 318, anyone see errors that I may have made? Or numbers I am leaving out?
Thanks all.
Here is link to compression ratio formula
How to Calculate Compression Ratios
so .085 in hole with .28 gasket wounder how much quench distance it have with a 302 head? anybody? i come up with .365 is this right? that tight from factory,..hummI dont have the #'s in front of me but I believe .085 average for 83 318 and 0.155 for the .030 over 70 318
Don't take that data from Summit...I have found plenty of errors on their data.
Stock weight is 592 gr and the pin is 161 gr.
If you are not running hard, I would go up to 5 grams if I was not caring, but I'd like closer. Google 'piston weight change for rebalance' and you will get answers higher than that.
It is not hard to drill some material out of the underside of the pin bosses to get them close to what you had. Or, since the pin walls are REALLY thick on these pins, just drill or grind some material out evenly through the pin's interior length.
You're not going to get a quench effect with any of these pistons....! Piston to head clearance is around .110" with the .028" head gasket and the taller 526 pistons.
You're getting there on CR IMHO! I am getting around 9.2 Static CR with:
- 302 heads milled .030", assuming the chambers are 64 cc's to start with before milling
- .028" head gasket
- The Sealed Power 526 AP pistons. These are around .077" in the hole and are the tallest stock type pistons around these days.
I have heard 58-62cc but have not measured myself. I do have a pair though.
