How about some information? Year / make / model, what is it? 4 speed? A833? Three speed gearbox of some sort? Automatic?Looking for information on a 1408517-10 transmission. What type fluid? Looking to clean up change fluid and sale it.
I'm not sure on any of this. I brought a slid of transmission and this is on it. On side it shows 54 PlymouthHow about some information? Year / make / model, what is it? 4 speed? A833? Three speed gearbox of some sort? Automatic?
Post some pics of the whole box. Might be out of a fluid drive or some such. Don't know
I've been told this is a old trans mopar overdrive. Found an other casting # r-10-g1.It appears to be upside down,lol
And appears to have a 10 spline input.
Very interesting.......
I was told mopar overdrive trans. Old. Tracing casting number.It appears to be upside down,lol
Ah, that would explain why it didn't look valid to me -- not a transmission ever used in the A-body era, and this is the A-body board, so naturally I assumed...!
Yes it's 19-1/2 in. Thanks for the help.If it has a "really really long" input shaft it's for a fluid drive. If not, conventional stick shift........
1952 56 plymouth standard with overdrive tranny with input shaft For A fluid drive bell housing Total length Of tranny from bell housing To back Of brake band Is 19 And halfinches
Msprout-- If you are looking to sell this unit please P.M. me as I could use it on my 53 Plymouth two door coupe.Yes it's 19-1/2 in. Thanks for the help.
Thanks now I'm working on a price to sell it.that OD unit appeared in mid 52 and was offered as a retrokit by the factory for 50-51 years though it will retrofit further back than that. the lube in that sucker is GL1 80/90...you can get it from Napa about 15.00 a gallon...only available in gallon size. Do NOT use GL4 and or GL5 as these lubes have shear additives and not good for brass parts. Modern lubes of these rating says they are compatable but if so WHY does the API still have specs on GL1 though GL2 and GL3 are obsolete...answer, because there is a need not to have the additives. The OD unit will also use the GL1. DO NOT get confused with some of the Dodge literature on 10 weight oil....those specs are confused with the fluid drive closed coupler and later in the semi automatic trannys of the era. This tranny is a standard gear box with OD attachment...the long input shaft just allows for use with the fluid coupler...
