Stop in for a cup of coffee
A man walks into a bar and when he sits down he hears what sounds like "Hey, that's a nice suit you have on". He looks at the bartender and says "Did you say you liked my suit?"
Bartender says "Nah, that was the peanuts...they're complimentary."
Master Craft or Ski Nautique are professional water sky boats that they usually use on the competitions... Master Craft uses GM v-8's and Ski Nautique uses Ford v-8's.... Both very good water skiing boats...
Never looked into them much. Straight in board? Planes faster with less wake with the engine more forward??????? If my memory is right.
Well, we got the deck framed up today. Just need to trim the end joists and attach the header on the front and it's ready for inspection Monday morning.
Do you have any braces between the joists? IMO you should have. Makes joists tons stronger. Just my observation. :thumbsup:Like ths
bad news.... i had the 401k thing figured out but the old company now playing games...... :BangHead::BangHead::BangHead::BangHead::BangHead:
Inspector will want to see the blocking tomorrow. It will need to be ready to be coverd and rails. IMO
This shows how the joists are attached, and how the ledger is bolted through...
Inspector comes Monday. Blocking isn't required by code, but we are adding it anyway. Only having the metal brackets at the cross-beam is required by code.
