If you didn't use new lifters when you went with the new cam, there's your problem.
The lifters were comp cam lifters and were replaced with the camIf you didn't use new lifters when you went with the new cam, there's your problem.
Well,thanks I agree because other than a few. Burnouts in front of the houseI think it was a combination of oil, additive, just bad luck was your problem.
isI think it was a combination of oil, additive, just bad luck was your problem.
Proud Papa to have it 37 Years ...........Very nice looking ride!
Actually there are quite a few oils that have enough ZDDP in them; you just have to do your home work to see which ones. In the olden days, the ZDDP levels were in the 1300-1500 PPM range. That got reduced to 1200 PPM and cams were not being lost. Then the ZDDP levels were reduced to 900 PPM's for one of the recent service grades, and that is when the problems started.You absolutely have to put a zinc additive in your oil these days. Or buy oil that already has it. No regular motor oil has enough ZDDP (zinc) in it to properly lubricate flat tappet camshafts & lifters.
Those 900 PPM reduced levels are for generally found in the the lighter grade oils, 30W straight and multi-grade, and lower. If the service code is SN, then you have a newer, low ZDDP level oil.
I never felt like the MP 484 lift was doing it justice , just wanted try a slight changeWhat was wrong with the old cam that prompted replacement?
That's definately pretty slight...lol.
Yea I Know..........That's definately pretty slight...lol.
Looks like a old RR hiding in the back ground.Well,thanks I agree because other than a few. Burnouts in front of the house
is View attachment 1715081887
