Well, as for the X block reducing ET’s or making more power, it doesn’t. The block is actually heavier than stock blocks. The benefit of the X block is strength and bore sizes available.
The reasons I stated above for the X block are not to knock anybody out but to say it is not a inexpensive route and actual cid size.
Would anybody here cheat on the engines cid?
I would hope not....
Making use of the X block requires a lot of money just in its purchase. Then you need everything else. I’m sorry, but I can’t see running stock heads on a 3K-3.5K-ish block price. (New)
Unless NASCAR rules demand it.
I don’t want to squeeze yellow rose out of the competition just on this along. Nothing against him. I do like the idea that this whole entire idea is “cheap.“
