Someone school me on header size.
doogievlg
Amelia, Ohio
i just spoke with a very reputable engine builder about headers for my 360. It is a .30 over 360 with flat tops, undetermined cam, performer rpm intake and Holley 750 dp.
The builder says if I go smaller than a 1 3/4” header I will be hurting the optimal power output. It looks like TTI makes a 1 5/8” x 1 3/4” stepped header. Would this be what he is referring to?
He must have in mind some real good heads and a cam that'll wind it over 6000 then.
The pipe size collector back can really screw you no matter what header primary if it's too small. Go 3" pipes, difference in power between 1 5/8 and 1 3/4 under 6000 rpm with the "average street performance" heads is small.
My thoughts..
I think you'll find that those stepped headers will perform just fine for you and won't leave much, if any, on the table.
As a basic description, but not limited to it, header sizes can vary greatly on any engine and have little effect. There is a point of cost vs. return and diminishing returns.
1-5/8 - Stock to mild street strip.
1-3/4 - mild street strip to medium strip
1-7/8 This and larger header primary size from here are pretty much for a strip car on a small block.
Cubic inch displacement should also be considered. If you have a stroker, every tube size description moves one spot. The 1-3/4 move downward to mild street strip because of the amount of exhaust your moving and how the engine reacts vs. the displacement.
Collecter size is designed into the header from the manufacturer based on its experience in this field so at one point, they said this header made better power with a 3-1/2 inch instead of a 3 inch.
Same issue with tube size. But that and all the parameters of a header can be constantly change for what there intended for and debated endlessly.
TO ANSWER THE TTI QUESTION
The step header is a bridge between the two tube sizes of a single tube header.
TTI does (or did?) rate the header for best area of HP output. It would s labeled good for. Example; 575 HP, next header, good for 750 HP
These are general guidelines. You can use them for more or less power with certain draw backs outside of there general recommendations.
IMO, it would be an excellent choice to use. Hedman makes a solid single size as well as a stepped header in various tube sizes. I’m not sure if they have what your looking for, but I would cruise the site and browse around there long list of headers to see if they have what you or your engine builder like.
From magazine tests I've seen, the TTI step performs better than regular straight 1 5/8" headers and as well or better than the straight 1 3/4" they tested. Works well in mild applications as well as higher performance. I have them on my Dart Sport and Aspen wagon.
Good mention locomotion. I have the Hooker Super Comps @ 1-3/4 on my 5.9 in my B body. It’s an OE ‘03 that has only a rpm intake, 600 carb and a older vacuum advance distributor that was chrome box fired. Everyone told me I’d have a huge loss of torque. I felt ZERO difference! and they fit excellent. Zero denting! I alsjust have a set on my E body 4 spd with only minor work to dent a tube to clear the scatter sheild.
Best header for high performance small block E bodies, though I have not tried the tti headers yet. Though it have no reason to try. As a note, they also require a smiliar clearancing for the scatter shield.
I found the article. Notes are added with each photo and the dyno chart for all is in the last pic.
Peak numbers are no where near as important as across the board numbers - "area under the curve".
TTI has the added benefits of better fit, thicker material, more ground clearance, easier installation and no need for the 90* oil filter adapter over most other headers.
While this shows a mild 360, mine is race only running as fast as 11.14 @ 117+ in a 3540+ lb car, auto trans & footbraking. I wouldn't use 1 7/8".
Exhaust on a Mopar 300hp Crate Engine - Tech Articles - Mopar Muscle Magazine
That’s a real chart for my ‘79 Magnum’s ‘03 Magnum I described. The “MASSIVE” lack of torque I was told I’d loose isn’t so bad! Seat of the pants would never let me know. The car was just a cruiser. 3.55’s with 26-1/2 tires.
Dougs will be about 5hp behind a set of tti's on a 360 with 440hp and that is really about it.
The hookers are worse than the Dougs and don't fit for crap.
We saw ZERO increase over tti going to a straight 1.75 or 1.875 header. The bigger headers were softer down low and no benefit to the top of the range at ~6K.
You should have sold me those TTi 1 7/8 for half of what you paid for them....LOL
Thanks for all the input.
I can not find a single 1 3/4 header for an abody. Everything is either 1 5/8” stepped to 1 3/4” or 1 7/8”. Am I missing something
TTI has the stepped 1-5/8 - 1-3/4.
Hooker has the straight 1-3/4.
(Thank you Tony!)
Perhaps Hedman has it as well. I’m pretty sure they do. It has been a while since I have been at there site.
I think 1 5/8 would be fine for your application. My 408 made 485 hp and 511 torque with 1 5/8 headers on the dyno.
How do I go to battle with a well known mopar engine builder over this?
“Hey man I know you have built thousands of wallet winning engines over the year and dyno tested countless small blocks but my buddies online say to use a different set”
Well, quoting internet ding dongs no matter how true it is what they say is going to go down in flames with any “Live” person. You would have to be delicate in delivery and express not just belief but trust in persons here. Pointing out frequency of the persons in there honest no nonsense replies as well as there honesty in not just what they claim to know but there forthright been there and done it story as well as those that say up front, “I don’t know.”
With no offense to @MOPAROFFICAL, @crackedback or @69dart500 (because your still brand new here though your posts on subjects are not in question in anyway shape or form.)
All the above posters I would believe and the most to place trust in for reasons at the end of this are;
@Locomotion; as he is a drag race competitor and multi time champ so, as he says, “In my particular combo!” He writes his post. He tells you what works and what didn’t “in his particular application.”
I don’t think Myron will mind a plug right about now!
Locomotion Racing - IHRA Stock Eliminator 1975 Dodge Dart Sport
@70aarcuda AKA TONY Is also a drag racer with several cars campaigning. He shows his builds right here and as close to real time drag slips as possible. He reports the days drag strip runs from victory to part failure.
While To y doesn’t have a web site as far as I know..... lick here for his profile page and scroll down and around. Look up threads he started. There you can find his transparency in his threads.
70aarcuda
Both guys are straight up people and offer the best out of all of us true proof of there words. Because if you look them up here at the site, they leave behind a heck of a trail of bread crumbs of no nonsense posts. Information that can be tracked down and in the books of record keeping at the tracks they race.
How’s that for proof?
My other compadres have been here for years. I can see who is smart and who is a smart ***. I give them a thumbs up all the way. Even if we don’t agree and throw spit balls at each other.
(Like siblings do! LMAO!)
Now! Lastly but not least in anything,
68dart500 is a new guy that is transparent with this awesome thread. Not knowing what would happen, he started this thread. So he is upfront and honest. Check it out;
408 Build- Guess the HP/TQ (Dyno Results in 3 weeks)
70aarcuda
There are plenty more on this forum that have been around along time and whose work I have seen go from trash to amazing on here. I would trust many members here to work on my car which says a lot considering this is the first time someone else has touched it in 13 years.
I wanted to let the builder make all the calls and not be a burden at all but this may be the issue I get stubborn about. I’m done dealing with the flange on hooker headers and the tti doesn’t seem like it will kill the power that he is worried about.
I've posted before, but in a nutshell, the T/A heads I did were on an AAR w/a 6bbl, 292 Purple Shaft, 9.5" converter, full street car with only slicks mounted for the track.
With a set of off the shelf Heddman 1 5/8" jobs & 3" pipes with turndowns at the axle, it ran a best of 12.35@109mph,...shifting~7200...I don't see Your needing more than
that, and the drive-around torque will be sooo nice!
Sounds like a killer engine.
Without knowing what cam you are running or the intended use of the car its hard to say what the effect would be.
Unless its a fully ported motor running a wild cam you wont notice the difference and it would have to be tuned to a nats *** to make a difference on a mild (400hp or under) motor. Big tubes might even hurt your performance on a mild street car.
