Like to see some pics where you guys mounting your remote oil filters,get some ideas.
340 '69 Dart it's a drag car only.
Thanks
Thanks
I put a remote filter on my car when I dedicated it to the track and built the new Stroker motor. It seem to always have some kind of itty bitty seep and was always suspect for me too cause a leak and a problem. I eventually just took it back off and used it 0 9 0 Mopar filter from Walmart. I mean it's what I used with the remote filter anyways. I thought I was going to stop pouring oil on my headers and things like that when I change the oil, but it was still a messed up on the fender wall. And again like it was more potential for disaster. All four hoses are another potential for a leak as well as another sealing point.Like to see some pics where you guys mounting your remote oil filters,get some ideas.
Thanks
So you really think that angle there is going to make oil spills less? I'm going to have to have you let me know how you're going to pull that oil filter off upside down and not have oil gush out everywhere? I mounted mine up on the fender wall just above that sideways. Tried to like cut out a plastic milk jugs to slip underneath it and still it's just a mess and more potential for disaster.I'm getting ready to put one in. I'm thinking that this area / orientation would work well for me and hopefully keep oil spills to a minimum. Decided to ditch the "push on" hoses and will go with AN mainly for the ability to remove\install the hoses. 2 short hoses bent around #8 header tube should be simple enough. I think.
View attachment 1715148151 View attachment 1715148152
When you remove the filter, it is going to dump oil all over the place. Hang it so you screw the filter on from below the thingamadoodle.
Reminds me of an old NASCAR driver (can't remember the name now)How about the Trunk? Just throwing the idea out there and see if it sticks?
That's how I've mounted mine, used some hoses a buddy gave me off an old ford PI.
Not that messy, put whatever you're catching the oil in under the filter and just loosen enough to allow the oil to leak out. After it stops gushing, unscrew filter the rest of the way. If you're quick with a shop towel under the mount you won't have much to wipe up. I've used old plastic microwave meal trays to catch the oil. They hold up very well to hot oil!
I put a remote filter on my car when I dedicated it to the track and built the new Stroker motor. It seems to always have some kind of itty bitty seep and was always suspect for me too cause a leak and a problem. I eventually just took it back off and used it 0 9 0 Mopar filter from Walmart. I mean it's what I used with the remote filter anyways. I thought I was going to stop pouring oil on my headers and things like that when I change the oil, but it was still a messed up on the fender wall. And again like it was more potential for disaster. All four hoses are another potential for a leak as well as another sealing point.
NASCAR drivers name also escapes me but he used a bunch of loins. I heard a reported extra 5 gallons of fuel. Very creative and sneaky. (Depends if your a fan or competitor I guess. LOL! )Reminds me of an old NASCAR driver (can't remember the name now)
But he was one who would read the rule book and look for loopholes
He had found out there was a limit to I.D. for fuel line, but not for total length, so he mounted a bunch of it to the bottom of the frame, enough to net him an extra gallon or two over everyone else on a full tank
Point being, what do you think the ful oil capacity of that system would be with the filter in the trunk?
And a second thought, would there be a pressure drop because of this?
Cole Trickle! LOLMounting the filter up and down with screwing it downwards
I have not seen any pressure drop in mine. Hose length is 8 feet one way. The 8 feet back.
Nice carb. Whatcha got on top?
