hula
Word of caution on a click wrench. My Craftsman , years ago, broke a couple of 440 head bolts when it was new. I took it to work, we had a Cal Lab, it was 23 lbs high at the setting of 70. They took the lead out of the end, adjusted the mechanism and resealed it. Now I check it every time I use it with my old Beam Wrench. Not that I think you over torqued it, but you need to check your wrench just for piece of mind. IMO.
I will. I had it set on 100 and was pulling up with one arm. It felt about like about 80 ft-lb, but thanks for telling me. It does look like I ran out of thread when I look back at the shaft.
