Steve Agrella
Checked the door switches no power to those both sides ??
If it's not the door switches and I would say it's your light switch.
if i'm not mistaken the door switches complete the dome light cir to ground so if you have a ground in the cir keeping the lights on there would be 0 volts at the door switches.Anyone know what might be causing the door switches no power also
go to mymopar.com MyMopar - Mopar Forums & Information - MyMopar Tools/Reference they have service manuals and wiring diagrams.It’s a 74 Duster
when you say you turned the light on and off at the switch do you mean you rotated the light switch to all the way clock wise and all the way counter clockwise?Sorry forgot to add I turned the light on and off at the switch.
Yeswhen you say you turned the light on and off at the switch do you mean you rotated the light switch to all the way clock wise and all the way counter clockwise?
could be.Maybe the switch is bad
so your door switches have 2 wires to each switch?power on either terminal coming
No blown fusesIs there a fuse in that circuit somewhere?
