moparmat2000
I had to change out my trans crossmember at the beginning of the build, and install a new floorpan. Somebody cut through the crossmember with a cutting torch cutting it in half. The one i used was from a 74 dart. The marking w arrow on this pic is where the crossmember bumped out for the cable , and the round mark is where the cable hole was. I cut out the bumped out metal in that spot so the connectors reinf transition plate could sit flat, then moved the cable inboard. There is definitely enough room. I mocked it up w a speedometer cable, and a zee bar and theres plenty of room to route it inboard of the framerail. I also slotted the rear footwell to run the subframe connectors through, and seam welded the floor metal to the connector. They only stick through the floor 1/2" some extra padding on either side, floor will sit level back there. The green paint is an epoxy etch primer.
