SS Lancer
What are you doing with this engine? The usual questions of SCR, DCR, cam size, fuel type and all that jazz apply. The pN 60779 version of these heads that you are looking at have 63 cc chambers, and that + a stroker kit will push the SCR/DCR well above the stock 318 levels. You gotta do the same homework each time.
Just doing some research , I might build a 30 or 60 over 318 and plan on running some compression so the heads I have were ported and the job was nice but I'm afraid they would run out steam on the 340 combo I had so doing some research and might put a nice 318 together with a tunnel ram and large solid cam and use the rpm 340 heads .
