Well, I got started today. ....radiator is out, fan is off and I'm starting to figure out how I'm going to attach the fans to the radiator. ..
Jeff
Jeff
Jeff
Thanks!Nice, I think you will be very happy with that setup.
Jeff
It's a Champion CC526 radiator, Summit fans and the controller is from TheAutoCoolGuy. ...What setup are you using?
Jake
Thanks!
And I'll be ready when I add AC down the road!
Jeff
My radiator does great when there's air moving through it....but after pulling off the highway and sitting at a few lights, things kinda get scetchy!It looks like I might be coming up on that same adventure before long.
The Wife wants me to put AC in mine, but I'm not sure I want all that stuff on my car.
We'll see, but if I do it it's going to get a nice oversized radiator.
Whats the point of adding AC if you are just going to be sitting out in the heat anyway with an overheated engine?
As for AC....I live and die by my AC....can't stand not having it in the Cuda! !
Jeff
It's finally let up for the moment. ..mid 90s....we were over 100 every day for 6 weeks!Well Chino isn't the coolest climate, so I totally understand.
I won't even go down to Phoenix in the summer (any summer)
Sure....can do it right now...Your fan setup looks great & I bet will keep it plenty cool now! I agree with you, the hardware bins @ HD are horrid. I've had much better luck @ Ace Hardware.
While you have access, could you measure your pulley diameters for me please? Just curious....
Yes...slightly but I couldn't really measure it back there....I'd say about 1/2" smaller at the most...Thanks Jeff. Is your crank pulley stepped down where the inboard groove is smaller than 7.5" ?
Sorry....a bit off topic
You having pulley issues? !!!Thanks Jeff. Is your crank pulley stepped down where the inboard groove is smaller than 7.5" ?
I've heard many times that the water pump pulley should be smaller than the crank pulley. ....
Jeff
Lol....nice!No, not any longer. Just went thru the pulley "rubik's cube" shuffle recently. I won
Pulley Diameters
Ok...I just went through that thread briefly. ...awesome thread....truly informitive.No, not any longer. Just went thru the pulley "rubik's cube" shuffle recently. I won
Pulley Diameters
Quick update. ..no luck scoring the hardware I need...I'll order it online tomorrow morning from McMaster Carr.
Jeff
