DartGTDan
'71 Dart GT Fan
Jeff, is the CC526 a bolt-in? Heard some people say they were warped/out of square they couldn't use it. Also, do the transmission lines line up? Did the mechanical fan not work? Why electric fans?
Yes....bolt in except I had to drill one hole in the radiator flange for the lower passenger side bolt. Bear in mind I installed it in a 68 Barracuda and I believe it's advertised for a Duster...Jeff, is the CC526 a bolt-in? Heard some people say they were warped/out of square they couldn't use it. Also, do the transmission lines line up? Did the mechanical fan not work? Why electric fans?
wish more do it your self peeps thought like you. do it like your gonna own the car for life.Got a little more done today. ...
I buttoned up the rest of the radiator and while I was down there I installed my starter wrap I bought a while ago. ..
I used these cool stainless steel ties and tool to hold it...
Then got started on the fan controller wiring. ..
I just don't like or trust crimp connectors any more so I always pull off the little plastic piece and solder and shrink wrap my connections.
Now that's a connection I trust!
Lots more wiring to go...
Jeff
Thank you and I absolutely agree.wish more do it your self peeps thought like you. do it like your gonna own the car for life.
thats awesome, all your work and money spent paid off.Ok...
Wiring is done....
Tested it out and everything works perfect.
Temp holds rock solid at 180 now....
Of course after weeks and weeks of Southern California weather in the 100s, it's cooled down now, but that won't last and I'll really test it.
Still gotta clean up some wiring but she's back on the road looking AND running cool!
Very happy with the results!
Jeff
More testing...went out in the peak heat of the day, around 92 degrees, and kinda romped on it quite a bitthats awesome, all your work and money spent paid off.
Seems to be sitting right at 190 degrees. ...as long as it doesn't get much hotter on 100+ degree days, I'm absolutely fine with that.
Worst case is I get fans with more CFM...but I think I'm good to go. ..
Jeff
Don't know exactly, but when they're off I'm charging a little over 14v....with them running, I'm around 13v.do you have a volt meter in the car? if so what is the voltage drop if any when fans kick on? i know its a soft start but just curious if any drop?
