Is this cam a stupid idea?
macdrew77
Camino, CA
Piecing together a carbed 5.9 magnum build with EQ heads going to cut for 2.02 valves and do a little porting. Hoping to use stock crank and rods.
I got this cam second hand for cheap and wondering if its a bad choice.
ERSON E994001
Grind RH 294/365
RH 302/365
110 Lobe separation 78 Overlap
Intake opens 37 closes 77
Exhaust opens 41 closes 81
Lift (1.5) 0.547 0.547
Duration @.050 246/252
Spring 130 closed 310-320 open
Ran the wallace DCR calculator and at 10.5:1 static it spits out 7.50 dynamic, which seems pretty soft. Is this cam a stupid idea? Finally got some money to dump into my Dart and looking for a nasty pump gas street strip motor, backed by either 3.09 low 4spd or a 46rh.
If you have magnum heads, your rocker arms will give you 1.6, not 1.5 as mentioned with that cam. Do a clay check.
7.5 is not awful for a street-strip engine IMHO... it could be a bit better but not much. Since you'll wanna rev this on the strip, I'd pick high RPM breathing over lower RPM torque.... not the same choice I would make for a straight street car. You'll probably use a higher stall any way with the auto.
Question: what pistons are you using? Getting that 10.5 SCR is dependent on those, and stock ones won't get you there without a fair amount of decking of the block.
I recommend 228-236 @ .050 ,on the intake lobe ,if running 4:10 -4:30 gears ,and a deep 3200- 3500 tight 9 inch converter .You want big camshaft, make it work correctly.
Too big ,in my opine....
My stock stroke 360( 10.3 ish compression) has a 260/264 565/565 lift cam on a 106 in at 102.
Stock rods, crank and pistons. At 3300 pounds its already been 11.20’s at 118+ with 1.54 60 foot.
Airgap intake, 1 5/8 headers into muffs
Seems to do alright
ERSON E994001
Grind RH 294/365
RH 302/365
I think something is off, I can't get to 78* overlap with your numbers. and how the heck you came up with 7.5Dcr at 3100 ft is beyond me. Hang on I got the 78*; 294/302/110 And I see how you could get 7.5, with an ICA of 69*(in at 102) and Scr of 9.8.....
What you didn't mention is the 135psi cylinder pressure, yeah I can see that working with the 3.09 low and 3.91s or better; 3.09x3.91=12.08...
Isn't that what YR runs; 2.66x4.56 =12.13 starter, and he loves it. But I don't recall his tire size. So by itself 12.13/12.08 isn't all that helpful.
But the problem comes, in street mode, when you hit second gear; cuz it's still 1.92 ratio, and your Rs drop to 62%, and with just 135psi...... well, you get the picture.
For the track,I would build the engine to plan on safely buzzing first gear a lil past "normal", and into "wasted space",lol, cuz if you short shift second and find yourself down at 3600, well you are gonna feel that 135psi as a big fat soft spot. The other two shifts are better at .729 and .714
Seems to do alright
Sounds awesome, If it's mechanical flat tappet...
Seems to do alright
Hydraulic roller?
Seems to do alright
Very impressive, this is a 5.9 or LA? How did you get the compression so high?
I think something is off, I can't get to 78* overlap with your numbers. and how the heck you came up with 7.5Dcr at 3100 ft is beyond me. Hang on I got the 78*; 294/302/110 And I see how you got 7.5, with an Scr of 9.8.....
What you didn't mention is the 135psi cylinder pressure, yeah I can see that working with the 3.09 low and 3.91s or better.
Ran the calculation at 300 ft. The cam specs could be off, they were on a piece of paper i got with the cam, cannot find any info on this particular one online
Undecided on pistons. Originally was going to use entire stock shortblock but I have the budget for new pistons. Anyone know of aftermarket pistons that match the weight of stock piece?
And KB107's piston+pin weights are only 8 grams heavier than the IC741's mentioned in the article above, so are another option. I assume the assertion that the IC741 piston+pin weight is the same as stock is true, as mentioned in the article. (I always have trouble finding info on stock 5.9L Magnum piston+pin weights....I'm gonna have to write it down someday.)
Verrry interesting. They're a hell of a lot cheaper than the Icons... Maybe a few grams could be shaved off even?
Just read a post on here where a guy measured stock bore 5.9 piston weighed 469 grams, pin was 135 grams, and ring set was 39 grams.
ERSON E994001
Grind RH 294/365
RH 302/365
The way I see it is ether use a smaller cam or go to another point of compression and use some race gas. (Or aluminum heads)
Ive got a stock bottom end 5.9 mag with ported factory heads, had the stock cam reground to 242/[email protected] .550/.550 w/ 1.5 rockers, on a 110 lsa. Sounded great, pulled like a freight train, and was pretty well mannered for street driving. The converter and tuning plays a big part in the streetability factor.
