how else are things going?There is....
Still in flux....how else are things going?
Hopefully it'll all work itself out. Stay strongStill in flux....
Question. I see some of you are grabbing tons of distributors. Why? Which ones? If you dont mind me asking. I would like a couple spares.
Post a I love you thread man! Not bromance thread I am not good under pressure!Hopefully it'll all work itself out. Stay strong
Hoppy, @halifaxhops , buys cores and rebuilds and custom tunes them. All sorts. He did a 318 poly points one for me
planning to do a small job sunday AM. not sure what time I will be back. probably at least 1Sunday around Noon????? 1, 2, 3?
Hey all. The 69 is sold, got my asking price......Just finished my jury duty.......
MJ?O yes he was. A child rapist....tough trial on me...
Nope....
Huh I think I missed that onePost a I love you thread man! Not bromance thread I am not good under pressure!
I hope you sentenced him to a brutal deathO yes he was. A child rapist....tough trial on me...
At least it wasn't anything major!So, I took the SRT out for a ride after work and at the first stop sign I hear water sloshing around...and a lot of it.
Crap. I figured it was probably the sunroof drain holes clogged so I went up and down some steep grades to see if would drain from any of the drains in the four corners. No luck.
Unhappy and not looking forward to the PIA of unclogging the drain tubes, I parked on the slope in the drive way and got my flashlight from the garage to inspect the inside of the sunroof.
Turns out it was bone dry in there and water poured down the drains runs out freely. WTF?
The inside of the car is bone dry and all the carpets at too. The AC drain if functioning normally too.
Mystified, I went on the computer and searched for anything similar. Couldn’t find anything.
So I went back to the car to reinspect everything and noticed that when I had the front passenger door open for a while, there was a slow drip from the bottom of it. I swung the door back and forth quickly a few times and sure enough, water sloshing.
Turns out the drain holes for the door were clogged. A short wire tool to clean the crud out of them and about a half gallon of water came pouring out.
Beer time!
Your civilian Doc is correct. The army docs are just looking to see if they can find a way to claim it’s just dehydration causing the seizures. I would be cautious about letting them draw any conclusions from it.Hey Dave,
So the Army docs want to do a test on my seizure stuff by putting me in a bod pod to sleep for 3 hours to measure hydration changes. My civilian specialist says that's not a test normally done and wouldn't have anything to prove for siezure cause. Ever heard of such a thing?
That's what I figured. Which is wierd since they cleared me off the medical review board but now want this testYour civilian Doc is correct. The army docs are just looking to see if they can find a way to claim it’s just dehydration causing the seizures. I would be cautious about letting them draw any conclusions from it.
They are just doing CYA hoping for cover in case anything ever happens to you on duty. If this test shows levels of dehydration, they will recommend a hydration protocol for you while on duty.That's what I figured. Which is wierd since they cleared me off the medical review board but now want this test
