Stop in for a cup of coffee
-4 F in sunny Fargo this A.M. Looking at dropping oil pan and installing center pu tube on Demon. Took several months for mother Milodon to send. Got tired of waiting on it so moved forward, now I get to undo progress and install it.
We really don't get -F here very often. Maybe a few times a year. And double digits are pretty rare, but can happen. However, with a quick internet search I found this - The state record low is −42 °F (−41 °C), recorded at Smethport on January 5, 1904. That's near the Northwest corner of the state. That is also the temp I ran my blast freezers at when I was at the cold storage. Was always fun to check for a fan motor out and even more fun to change one. :eek: Regular freezers mostly ran -20F.
But just as it plays a part in feeling heat, the humidity makes you feel the cold. I really noticed it in the last week . When it was in the 20's (and dry air)I was fine. Mid 30's it felt really raw. Difference is the moisture transferring the cold.
Moisture? I like moisture!
hey all, hand is in a cast, had much needed but put off surgery on left hand. i am left handed......pita. hurts like heck...
Hopefully it will heal properly and quickly...
In the meantime you will get more coordinated with the other hand...
<<<Where's that Daffy Duck meme????>>>
Yay that time of year and that day of the week.
I just pull down the cover from my smoke eater in the ceiling, of the shop, to clean it, and change the charcoal filter. Man that thing was nasty...:lol:
Imagine all that in your lungs. :eek:
You are way too hot to waste your lungs on something that has no point in life like a cigar.
:soapbox:
2011 superduty. No dome lights. Code says shorted to ground. Great.its a good thing i left all my circuit tracing equipment out. I spend anothe hour and give it a rest,have to troubleshoot more wiring in town.
