Anyone use connectors like this? Are they as good as the videos for them make them look? Thanks in advance.
https://www.amazon.com/dp/B07JGQFJK2/?tag=joeychgo-20
The hb freight doesn't have the soilder like these. Cost more but I believe is a better product.HF sells a little "marine" shrink tube kit with the waterproof goop inside (cheap alternative)
I purchased the Amazon brand and the plastic tends to start melting before the solder. I tried a mini butane torch as well as a heat gun with the same result. I would recommend a better quality item in the future. The idea is good, though.Anyone use connectors like this? Are they as good as the videos for them make them look? Thanks in advance.
The shrink tube shrunk before the solder melted on these but I just kept sweeping back and forth and turning the wire and the solder melted nicely without the plastic melting at all.I purchased the Amazon brand and the plastic tends to start melting before the solder. I tried a mini butane torch as well as a heat gun with the same result. I would recommend a better quality item in the future. The idea is good, though.
I purchased the same connectors. Except it took 6 weeks to get mine. A little fact that was not made clear at the time of purchase. They take orders than drop ship from China. But they are a good product.I have used these yesterday. They seemed to do a really good job. Very easy to use. My only issue was after I ordered these it took 4 weeks for delivery. Inexpensive waterproof is much better than crimping. The low temperature soilder melted quickly. As in the add I pulled on the connection as a trial and it didn't pull apart.
