I feel your pain brother, my daily driver is roached, I get the second hand me downs, the wife gets the better end of the deal always, as it should be. If your truck is the money maker, you got to have it to get to work, no choices there.
Had a similar problem with my Jeep, CV joint front driveshaft, on my third one, this time I carefully took it apart and only found just a small amount of grease on one side of the bearing shell. This time I filled it up with CV lube, and it has been three years...knock on wood. So I have to side with AJ on this problem, just enough grease to get it out of warranty.
