Hey guys. Installing my 5.9 Magnum crank to check clearances and found my King rear main lower bearing is nicked up. Did a quick search and it doesn't look like I can purchase just 1 bearing. The scratch is on the inner/crank side of the bearing. I hit it gently with some 250 to knock the high spots down. Do you think it's usable if I clean it up with emory cloth? Thanks.
