Looking for best tip on disassembling a door
MonkeyMadness
Yorba Linda California
I have a door with cancer that i cant save. I have a donor door shell to takes its place.
My question is what the best way, and in what order; to disassemble the door.
If there is a certain order in which i can take it apart with ease and reassemble with the same ease that would be great and i welcome any and all tips.
Door is removed from the car at the moment.
Thanks
j
Lock knob
Top sill
Inside handles and arm rests
Door panel
Glass
Mirror
Regulator assy and rails
Hinges, latch and outer handle
If your door has a wing window it can come out the same time as the window and regulator assy.
You didn't state what car. There was a link posted in recent thread where they detailed glass install and alignment process for hardtop.
A tip that may not apply, there are glass travel stops somewhere, limit how far up/down the glass will go. Some are mounted to the door with bolts. In many cases a eccentric stop in the regulator limits downward travel. Hex nut with flat screwdriver slot in its center. Adjust it to lower glass further into door, fuzzies will R&R much easier.
Yes. Sorry forgot that part. It a 65 barracuda, passanger door.
TAKE PICTURES !!
Yes thank you, this is part of the plan!
Download a shop manual, has all the info step by step. Am using it now on my 73 Sport, cleaning and renewing all the innards of the window and lock mechanisms.
