AJ/FormS
68 Formua-S fastback clone 367/A833/GVod/3.55s
- Joined
- Jan 19, 2014
- Messages
- 26,611
- Reaction score
- 13,844
Is that a puller-fan?
YesIs that a puller-fan?
The thermostat sets the MINIMUM coolant temperature. It has nothing to do with the maximum unless it is restrictive or stuck closed.Got any ideas?
It's not. That's why I'm trying to figure out what is limiting the cooling. The radiator is a Champion 3 row and is rated for WAY more HP than I have.The thermostat sets the MINIMUM coolant temperature. It has nothing to do with the maximum unless it is restrictive or stuck closed.
The cooling system efficiency sets the high point. At 70 mph and in 5th gear, your cooling system should be at or near peak efficiency....... if it was working right.
Well maybe the condenser in front of it is acting like a sheet of plywood.
My recollection is yes, there are different pulley combos for a/c and non a/c and maybe for trailer package too. last pages in the cooling section of the shop manuals.Why don't I just pull over and shoot both of them with my IR thermometer . They can't cool off that quickly.
Isn't there a smaller pulley available for the water pump? That seems easy enough to try, given all the crap I've already done. The delta T will change with increased flow rate.
This is from a digital '73 Dodge FSM
It shows the pully ratios but not the diameters.
The smaller impeller A/C water pumps get a different drive ratio.
There are a couple of threads here on the topic of OEM pulleys.
I'm not much help on that.
Thanks! It validates what I think is happening. I'm anxious to try it.Some good threads on pulleys.
https://www.forabodiesonly.com/mopar/threads/pulley-diameters.411119/
https://www.forabodiesonly.com/mopar/threads/pulley-size-for-72-340-with-ac.420375/
March makes aluminum pulleys. You can order in black finish (powder coat). So yet another option.
Haven't tried that. The load on the engine would be different for sure. I will try it tomorrow just to see.Waitaminite I got an idea
What does it do when cruising in direct? at same speeds as before.
I'm definitely nowhere near opening the secondaries. The poor mileage was because my vacuum advance wasn't working, I'm sure. Haven't verified that yet but feel pretty confident it will be improved. Plus, was able to go to a leaner setup with the changed timing.Waitaminite I got an idea
What does it do when cruising in direct? at same speeds as before in od.
And what are the secondaries doing?
Here's where I'm going;
What if
in od, at cruising speed, the 360 is so underpowered that you are deep enough into the throttle that the secondaries are opening? I mean you said the temps start creeping up at 70ish right. I know any 360 should pull that with 3.55s relatively easily in direct gear. But what about yours in .79od? If your secondaries are not opening, it's gonna take more throttle in od than in direct to cruise at the same speed. In direct, at 60mph the carb should still be on the transfers, with a very small throttle opening. By 70 the mains may be contributing, it depends on your cylinder pressure and fuelling.
But in od the throttle may have to be opened more to get enough power to cruise with. So maybe the mains are flowing. This would simultaneously point to both the lack of fuel economy and the engine is working harder to maintain 70. Just thinking. Now throw in the possibility of the secondaries being cracked, and that would be another can of worms.
What if is all I'm saying.
First thing I'd do is check the advance on the other distributor. If its a shorter advance, then swap vacuum cans and be done with it.
Again. 7* BTC on a stock engine isn't out of line with what you would have got from the factory. So what you'll be doing by bringing that up is making it more efficient.
Articles. When you find 'em, many are half sales pitches and regurgitations of the same.
Your goal is to cut the bottom off the curve.
Disassemble the distributor. Hardest part will be removing the snap ring that's under the felt pad. Second hardest part is removing the reluctor. Take a photo or notes before removing it to remind yourself of which slot the roll pin uses.
With the snap ring and reluctor removed, the rest is straightforward. Slightly lift the plate to free the vac can arm.
Here's a cam plate (aka slot plate) in the initial position. Zero advance.
The primary spring's tension holds the weights against the inside of the slots.
Remove the cam plate. If you were me, I'd measure the slots and distance between for baseline reference. Or you can go from the internet alone if you prefer. LOL.
The stamped number represents the advance distributor degrees allowed by the slots.
Your distributor #2 seems to have about 28* in it. (It may be stamped 14)
You're looking to reduce that by 5 or 6* to 22* advance.
My notes show that 22* will require slots 0.410" long. You can find some other folks findings on the net and their similar.
Weld a tack on one or both of the slots. On the inside! carefully file it back to slot length needed.
Reinstall.
(if you see differences in the photos, its because the photos are of several different distributors)
