Hi there,Any reason you are advancing the cam an additional 2 degrees over the 4 degrees of ground in advance? I ask, as your DCR is pushing the mid 8's and the added advance just increases it.
Got a plan to start lower on the initial ignition timing, and slower on the ignition mechanical advance, and then work it up in stages? From what I can see, you are bumping DCR MORE than 1 degree with the drop in chamber size unless your X-heads were milled down some to smaller chambers. If you had detonation issue before, and you jump up over a point in DCR, I would not expect the AL material alone to keep you out of detonation.
Thank you for your response.
We'll originally I had installed the cam dot to dot.
Regrettably I did not degree it.
So I really don't know exactly where it is.
It seemed a bit lazy on bottom end and only had 10" of vacuum with 20* initial timing
So I moved the timing set to the 4* degree crank advance key way.
It picked up some bottom end and vacuum went up to 12"
Cranking compression also went from 165 to 170+
After playing with the distributor, carb, pcv valves...etc vacuum came up to 14
The x heads have been milled to 66cc
Running 91 I could only put 32* total before it would start pinging.
If I need to I'll put the cam back to where it was.
I'm also hoping having some quench .044
Will help it some too...
