72demon440
Looking for another set of eyes to look at my pictures. 72 Demon with 60 over 440, 4 speed A-833, centerforce clutch, custom drive shaft, 489 8 3/4 355 gear. Need help seeing what i have wrong here. The cut out in the oil pan is not located correctly. The motor mounts were in the car when i bought it in 2005. Appear to be correct offset (schumacher??). K member has been cut out for oil pump approx 1 inch long. I bought a pan from mancini. Still have the typical steering issue hitting the pan. Not sure what I am missing. Not sure how much the engine can go up also?I know this conversion is a pretty standard thing. It will be getting TTI's next. Any help you can give me would be helpful. Thanks in advance, Jared
