My Leaning Tower
325HP with the pistons that far in the hole at TDC? What all has been done to the head?
I thought the same thing, that's for sure 7:9:1 compression ratio with the pistons that much in the hole. 325HP gonna need 10:1 or higher. I know a guy claiming his slant is over 300hp running that .440 lift compcams grind. I don't believe it for a second.
Cool story, bro.
Its was 8:9:1 from the factory with dished pistons. Those pistons are 40 over flat tops. Plus how many engines have you built?
No slant came from the factory with dished pistons. Slants were rated 8.2-8.4 CR by the factory, but I have never seen one that even hit 8.0-1 when actually measured. Not trying to beat you up, but just pointing out some things. Maybe someone is misleading you.
PS: Just a FYI, I have lost count on how many slants I have build since 1974. I have 5 on engine stands, in various stages of build, at this time.
It is 10 to 1 compression. The guy that built the engine is Randy McDowell at Power Tech Racing engines in Ashland Ky. He has built engines for track and drag strip for over 30 years. He can build engines and make them within 2 to 3 horsepower just form the formulas he uses to build them. Its was 8:9:1 from the factory with dished pistons. Those pistons are 40 over flat tops. Plus how many engines have you built?
No one is raggin on your engine, man, so there's no need to get defensive or insulting. Unless your engine's pistons were not all the way to the top of the bore, that engine has at least .100" deck clearance. In other words, the pistons sit .100" down in the bore. Unless you're going to run an outside power adder such as forced induction or nitrous, you'll not get to 325 HP. Here's the deal there. The cylinder head on the slant six is the limiting factor. It was designed around the 170 and never redesigned around the 198 or the 225, so the larger engines got the 170 cylinder head. There's no amount of work you can do to a slant six head to achieve 325HP naturally aspirated and carbureted at your compression ratio level. You'd have to build a slant six so radical that it would not run on pump gas. A 13.5:1 225 bored .100 over with zero deck pistons and a totally ported head with huge valves and an equally huge camshaft MIGHT do it. Then again, it might not.
We're not raggin on your build I think it's nice. But if you've been told by someone that it's going to churn out 325HP, it ain't happenin. Also, "I seriously doubt" it has anywhere near 10.1 compression. Those pistons sit a LONG way in the hole at TDC. Even if the head's been milled so the combustion chamber is totally FLAT, you're not getting to 10.1, not happenin.
Now.......before you smart me off and ask me how many engines I've built, my answer is "I don't know" A damn LOT, I can tell you that. DO I know everything? Hell no I'm learning everyday, but I know what I've told you is correct. If you've paid for all you say someone has told you, my advice to you is to do your own research, measure your own compression. You'll find out the information you've been given is incorrect.
Again, we're not trying to rag on your build. I'm building a slant right now. We love them. We're trying to help you. The best thing to do is listen.
Here is a pic of the 225 from my 63 Dart. 64000 miles & everything looked great inside so just getting a refresh & reseal. Should have the Dart back from paint by the end of the month so I can get it back together hit the car cruises & shows here in NE Ohio. WOOHOO!!!
Looks great,I may paint mine the same.
Of course since yellow add so much hp....maybe Caterpillar yellow.
Lmao
I really like the red though and it probably get better mpg and last longer.
About two going on to my third,and I don't have people build my motors for me I do it myself and if it fucks up oh well At least I know and I learned from it. Factory compression lol was 7:9-8:1 at best. Stock slant six were were 90-100 horsepower at the wheel. No way your even at 200hp. Probably can't even chirp the tires lol. Who ever is telling you you got 325hp is blowing smoke up ur a$$.
Yea Im sure you are a legend in your own mind!!
Not to be ragging on you, but I see you are a new member. There are over 51,000 members on this sight. I'm not one of them, but there are some on here that probably could be considered legends, and not in their own mind. Some like RRR and slantsixdan, are extremely knowledgeable, and are willing to share that with us who aren't. Showing your RoadRage, here, will not make you very many friends.
Can we get back on topic here, please? This is @petty437 's thread. I would love to hear more about your build, @RoadRage so please start a thread for it. Thanks.
Roadrage came along and hi-jacked this topic and got it off track. And I'm sure that has scared off petty437 as well.
Yep, sorry, I lost track of the original poster.
See what I said to Rusty!
@petty437 please continue with your build progress. We're all wanting to see it. Thank you.
Again, I think this topic has scared him off. That to bad as I was interested in this as well!
It's no wonder I don't post much on this site when I read & see so much crap like this here!
Well I know Dan from SL6 forums. He is a know it all. Always finds a way to be a buzz kill and run down anything you post. if he doesn't approve, it cant be done. Im not a new member just changed my SN. Dan is the reason I left that forum. Got enough negative to deal with I dont want it here.
