SeattleQQ1Fish
I decided to pull the heads off my 273 to change the valve seals, scrape off 50 years worth of grime, etc.. I pulled off the passenger side exhaust manifold and found the manifold heat control valve welded about 70% of the way closed. Is there any reason for someone to do this? What was that doing to the performance of my car? It never has run right.. My first instinct is to saw the thing off, plug the hole and forget about it. Is that going to cause any issues?
Here is the sleazy little weld they closed it with
