512Stroker
We are all here because we are not all there.
So you used factory Hyd rollers.Again LA blocks had factory roller lifters from the late 80's to 91/92.
No retrofit kit needed. All I needed was the hyd. roller cam itself. The block already had roller lifters from the factory.
Here is what I used: Voodoo Retro-Fit Hydraulic Roller Cam - Chrysler 273-360 270/279 (No lifter kit needed)
But now I want this: Voodoo Retro-Fit Hydraulic Roller Cam - Chrysler 273-360 282/290
Or maybe: Hughes Engines
It is the aftermarket Hyd rollers that I and others are having issues with like the Comp cam Hyd rollers that bleed of very quickly causing excessive clatter on startup.
