With my luck, the other end of the hole would come out under the house.I'd pull the hose out and light it!
Here’s what happened to this guy when he did that...I'd pull the hose out and light it!
BAHAHAHA...
It's so much less entertaining...Red neck is right.
Just put some gopher pellets in the hole.
So much easier.
I too, have a mole problem evidently. Just moved some stuff around in the garage and watched one scurry of to another hiding spot. All I did was look like this.We don't have gophers around here but looks like something I could try to get rid of moles!
So you have a gas can shovel and dry vac.
Can you give me a step by step run down on this ?
Wife said NO POISON cuz we have cats.
So I waited till she was gone and poured gas down the hole then stuck the shop vac and pushed the fumes thru the entire tunnel network.
Gophers die underground. No problems.
Your method has about a 1 in 1 million chance of working.
