Yep, lots to do and don't feel like doing nothin. LOLLots of honey do's today. stay safe.
Yep, me too. Did the yard work yesterday. Cold outside today and snow coming sometime. I need to do laundry. Good inside project. I will sneak over to the storage garage and get the snowblower out and running. Going to need it soon.Yep, lots to do and don't feel like doing nothin. LOL
That reminds me, I need to order a couple snow blower parts. Dang, I should have done that earlier instead of having heart surgery! What was I thinkin'!Yep, me too. Did the yard work yesterday. Cold outside today and snow coming sometime. I need to do laundry. Good inside project. I will sneak over to the storage garage and get the snowblower out and running. Going to need it soon.
Wassup!
No tellin! That whole surgery thing sounded like a bad idea from the get-go.That reminds me, I need to order a couple snow blower parts. Dang, I should have done that earlier instead of having heart surgery! What was I thinkin'!
Agreed but better than the alternative. LOLNo tellin! That whole surgery thing sounded like a bad idea from the get-go.
Was it sagging in the rear ?
Bill
I swapped the snowblower and pressure washer between the garage and shed a couple weeks ago. Need to give it a look over, but I think I only used it a little bit after changing the rubber 'blades' and scraper.Yep, me too. Did the yard work yesterday. Cold outside today and snow coming sometime. I need to do laundry. Good inside project. I will sneak over to the storage garage and get the snowblower out and running. Going to need it soon.
And goodmorning!
-16c, or damn its cold.
Wonder iffn the fargo will start?
Think it is a 77 up truck, not sure.That's a high number.
Could it be a p-part?
MP sold a fairly common Kelsey Hayes adjustable for many years.
Exactly the parts I need to replaceI swapped the snowblower and pressure washer between the garage and shed a couple weeks ago. Need to give it a look over, but I think I only used it a little bit after changing the rubber 'blades' and scraper.
I get 1-3 years out of a set depending how many times I run it.Exactly the parts I need to replace
I waited way too long to split all this firewood. Some of it is getting old and still not dry right. So, Hopng that stuff but ns OK this season. Dont want to have to get rid of wood That gets too old to burn. Plus it’s a way more than I will buy n before it is done ven w
Pull fuse, put an inline switch and fuse in its place.My cousin is a carpenter and have a van, and with the doors open for a long time when he is in and out the battery goes flat. So, he asked me, what would be the best way of solving that. There is no switch in the car to turn off the lights. He asked if he could have an extra battery with some kind of relay so the relay will switch off when the voltage is low enough and thereby cut off the extra battery for the lights from the battery the car need to start with. The problem with that is that when the voltage is that low, the car will not start anymore either.
I wonder if a timer would be an idea, open the door or push a button, and the light is on for so long and then goes off.
Bill
He say he is not sure he will remember to turn the switch off always... I can see his problem, when the day is over and he is going to drive home, it is no power to start the engine. And, during wintertime northern part of Norway does not have a lot of light, so he can not use a solar panel.
Bill
If the bark is on, and your area is on the moist side the wood inside can start to rot before it dries. But, usually when you split it, it will dry. You will have a little reduced heating energy in such firewood, but it will still burn, and rotted stuff that has dried will burn too.
Can you buy firewood on the root here, I mean can you go to someone who has forest and ask if you can cut down some of his trees to clear up his forest, and pay a little fore it, and he get a job done too, and you get inexpensive firewood ?
Firewood is an amazing invention, it gives heat so many times. It warms you when you cut the tree down and chop it up. It warms you when loading it in the tractor trailer, or whatever you put it in, and it warms you when splitting it, and it warms you when stacking it, and it warms you carrying it inside, and then finaly it warms the entire house when you put it in the oven.
Bill
