Yup. Talked to my brother about 3 hours ago. Now, the surgery is Tuesday at 10 AM and she needs to be at OHSU at no later than 8 AM.
Sooooooo...if OHSU doesn't bone us again hopefully my mom will be back to normal in 2, maybe 3 weeks. That's means I'll be home just in time to load my junk up and head back over for the NWDRA swap meet!
Hopefully after that, my distributor machine will be up and running, and then I can settle down and start researching pistons and then bite the bullet and determine if I can use a mushroom lifter with this block. I may have to use a roller, which I'm not really wanting.
And, I need to figure out exactly what this block is, do a clean up bore on it, sonic test it and the settle on a bore size. And find a set of 6.250 rods and a hopefully an off the shelf piston that has a .927 pin.
Then, and only then, can I get on the flow bench, test for valve size and shape and then order valves.
Lots to do.
