You are probably binding the converter snout. Sometimes turning the converter disturbs the bind "enough." Sometimes what helps me is putting longer headless bolts into the lower large holes to act as guides
Well I knew cutting myself with the cutoff wheel yesterday made me loose concentration.
This morning I went out to the garage and was like, dumbass, your trying to put a 7/16" bolt in a 3/8" hole!
Once I grabbed the right bolts it went right together.
So I also ended up cutting out more of my original upper crossmember. So both of the inner mounting holes have been removed. Could have probably left the passenger side intact, but would have had to make some weird bends on the steel i'll be putting in, and to just keep things kind of symmetrical, I cut both sides the same.
Looking good! What are the four holes in the floor for?
Yes, did welded in subframe connectors a few years back. They don't show in these pics but they are just outboard if the torsion bar sockets.Do you have subframe connectors in this car?
See the post right above yours. 1/4" thick plate bent into a hoop that will be welded in place of what I cut out. It will be welded to the top of the tunnel, on the sides, and to the ends of where I cut the original out at the bottom on both sidesWhat are you doing to the 'vertical' portions of the cross member, where you've trimmed it to make room for the trans? That's where the strength for accommodating torsion bar loads comes from.
Did you take what you cut out as a "template"?
I'm kind of skeptical if that 1/4" bar is really enough, it would be better if it was a box structure like the original for sure. In bending "cross-car" (think passenger side to right side as arrows show) with stress from the suspension rising and falling, I doubt it has much strength. The floors have very little strength outside of the crossmember.
Well, I'm kinda just winging it, based on what I've seen other people do. I've read every thread I can find on this swap, probably multiple times. I realize the channel shape of the original member is probably stronger, but fact is it has to come out to do this swap.I'm kind of skeptical if that 1/4" bar is really enough, it would be better if it was a box structure like the original for sure. In bending "cross-car" (think passenger side to right side as arrows show) with stress from the suspension rising and falling, I doubt it has much strength. The floors have very little strength outside of the crossmember.
